WH-1000XM3 FOCUS ON VOICE
Frogster99
Hi all i have just bought a pair of these headphones after all the good reviews and i'm just finding my way around the software. I have one question which is baffling me. This is the Focus on voice tick box. The description for this says noise canceling but if an announcement is made or some one speaks to you you can hear that voice. On mine it works opposite while unchecked i can hear voices and when i check it it cancels out voices. Maybe i have got it wrong.
1 REPLY 1
Pascale_F
Moderator
Hi Frogster99,
This sounds confusing. You could try contacting
Sony Support to see what they say?
Thanks,
Pascale
