- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Can someone help me as this is driving me crazy?
Just purchased these headphones recently and whenever I connect them to my phone (Samsung s20 5G) I don't hear ANY notifications on the headphones - the notifications play on my phone but no sound whatsoever on my headphones so I have no idea that e.g. a text message has arrived when I have my headphones on. Music plays fine. Google Assistant works fine and will read back a new text message but I want to know when they arrive so that I can listen to the read back.
Any ideas why this is happening?
P.S. I just tried with an old pair of bluetooth headphones and these work fine i.e. notifications come through so this is a Sony or Google Assistant issue - any ideas??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Final update:
Installed Tasker and set it up - excellent product.
I can now use Google Assistant even though I don't get notifications as Tasker tells me when a text message or email arrive (using Notification Listener plugin). It also tells me who is ringing me when I receive a phone call with my headphones on. Brilliant!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @HughPMF,
to which phone did you connect the headphones?
Maybe you are right and the fitness band interfers - does the band vibrate by any chance? To notify you of any incoming messages?
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
They are connected to a pair of Sony WH-1000XM3 headphones. I've established that this is only a problem with Google Assistant as Amazon Alexa works fine and I get the notification sounds. However, Alexa is really dumb when it comes to managing the phone (so can't read out text messages or even recognise what music I'm playing unless I open the relevant skill first). Google Assistant is so much better but I don't get the notification sounds even if I switch off Spoken notifications.
The fitness band is definitely not interfering (and it also gets the notifications).
I'm wondering if this is a problem with Google Assistant on my phone which is relatively new (a Samsung S20 5G) .
As an aside I'm looking at using the Tasker app (from the Play store) as a work around as this can send a spoken notification when messages (etc) arrive and can be configured to only do this when my headphones are connected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Final update:
