WH-1000XM3
Clarkie00
WH-1000XM3
Im concerned that every time i put the headphones on, the side arms flex to the extent that the arms look like they are going to snap. Over time is has weakened the supports and occasionally the wiring of the arms come out of the sockets. I feel this is a serious design fault. Has anybody else had a problem and if so what is the solution. I do not have a large head!!
Tags (1)
1 REPLY 1
RottenFoxBreath
Enthusiast
Sounds like you are pulling them apart far to far then plonking them on and letting them snap on to your head..why, just why?
Be more careful.
You don't need to stretch them so close they will be close snapping, just wide enough for them to slip over your ears, on max length, then adjust when on, then that should be them, I would guess forever.
And if the wires are coming out then I guess you have stressed them.
Either that, or no matter what you say, your head is like a melon! 😀
And yes, I have these as well, and I have a big head, and with a years use, no issues whatsoever.
