- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Supplied wall charger has 1500 mAh power output. Doing simple math means 4 hours and some minutes is a bare minimum. When device is on (screen off) some power goes to device, there is also some energy loss during charge process itself. I think up to 5 hours for Z2 tablet with fully discharged battery is near to normal.
Also try to avoid discharging the device below 10-20%. This way you can extend battery lifespan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ernestorendonb,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
How slow is the device charging, what type of percentage an hour?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and thanks, I think it takes likes 5 hours from 0 to 100 percent
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ernestorendonb,
In most cases the tablet would be at full charge within 2 to three hours if charged via a Wall outlet. This may be due to applications running in the background when trying to charge the tablet.
I suggest that you restart the tablet before you start the charge process.
Let me know how you get on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks a lot im going to try today
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jake, it took 3 hours for 60% of charge, its that OK?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you try loading the device in to Safemode and then trying a charge to the device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Im going to try and I give you notice forward
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It took 3 hours to go to 60% in safe mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Then it took 1:45 to go from 60% to 100%
