Problema installazione nuovo decoder DVB T2
endriu7
Nuovo
Ho installato il decoder DVB T2 su una TV Bravia KDL-32BX300 ma non riesco a vedere i canali che trasmettono in alta definizione (riesco invece a vedere il canale 100). Premetto che gli stessi canali in alta definizione riesco invece a vederli senza il decoder (ma non vedo il canale 100) quindi non è un problema di segnale. Ho verificato che il decoder funziona, perchè l'ho installato su di un'altra TV e funziona correttamente.
Qualcuno cortesemente ha qualche suggerimento su come risolvere questo problema ?
5 RISPOSTE 5
royabrown2
Eroe
@endriu7
You may do better on an Italian Sony Community than here, but please anyway post in English on this UK Community, as:-
Problem installing new DVB T2 decoder
I installed the DVB T2 decoder on a Bravia KDL-32BX300 TV but I can't see the channels that broadcast in high definition (I can see channel 100 instead). I state that the same channels in high definition I can instead see them without the decoder (but I do not see the channel 100) so it is not a signal problem. I verified that the decoder works, because I installed it on another TV and it works correctly.
Does anyone kindly have any suggestions on how to fix this?
So I can see that Italy is going to DVB T2 very soon, and presumably you want to use a decoder with this 2010 HD-Ready TV.
But we don’t have DVB T2 decoders in the UK, except already built-in to TVs, so we may not be very familiar with them. How do they work? Do they bust the DVB-T2 signal down to DVB-T, and still go into the aerial socket, or do they feed in over HDMI, or what?
If I took a wild guess, I would say that your decoder is expecting a Full HD (1080p) TV, and not an HD-Ready (720p) TV, and maybe there is a setting on it you can change for this.
What is the spec of the TV that it does work on?
Ciao @endriu7, il TV in ingresso da HDMI accetta anche il FullHD quindi un segnale 1080p, probabilmente il problema è un'altro ma puoi comunque tentare la modifica delle Impostazioni Video nel Decoder.
@royabrown2,
Yes! A DVB-T2 Decoder is connected to TV by an HDMI cable... (now, before via SCART).
But, 32BX300 accept 1080p from HDMI.
Anonymous
Non applicabile
Ciao @endriu7, ho spostato questa discussione nella Community di Sony Italia poiché era stata erroneamente pubblicata in quella del Regno Unito.
La discussione può continuare qui.
@royabrown2 e @Marino.Manolo, grazie per l'aiuto.
Hi @endriu7, I moved this thread to the Sony Italy Community as it was incorrectly posted in the UK Community. The thread can continue here.
@royabrown2 and @Marino.Manolo, thanks for your help.
Alessio
@Anonymous grazie e scusa, avrei dovuto avvisarti taggandoti nella Discussione.
Anonymous
Non applicabile
Nessun problema, @Marino.Manolo. 🙂
Alessio
