Bluetooth issue with Android 8 :(
frank06
bluetooth continues to fail android oreo 8.0.0 in sony xperia X, when the security patch for this device will come out. shame
5 REPLIES 5
profile.country.NL.title
Strampke
Fail.
On the vast majority of the devices it works without a problem.
Can you explain a bit more.
Maybe there is a way to get things going again for you.
eldigsi
Hi!
I don't know if I have the same issues as Kudos but I am experiencing a lot of problems with two Bluetooth Smart (4.0) devices and my Xperia X phone as it frequently loosing the BT connection and I have to restart the phone to get it to work.
One of the devices is a Huawei Honor Fit Smart Watch, and the other one is a heart rate monitor of unknown brand.
If I open the BT pairing window, I get an exception message about every three seconds that is  popping up on the screen each time there is a status change of the BT connection, something like "Instantiate Action error - java.lang.ClassNotFoundException:invalid name: com.woodslink.android.wiredheadphoneroutingfix.action.internal, Unknown version 0.0 ACL_CONNECTED (or ACL_DISCONNECTED) ... and similar exception messages
When can one expect a fix to this?
Anders
Udzzis
Anders, your error most likely is related to the SoundAbout application, try to uninstall/reinstall it. I had the same error, and after removing SoundAbout it disappeared.
Onishif
I have the same issue, but after unistall SoundAbout, I cannot use HeadPhone anymore. It is not reconized.
Ivi_Gie
Hi!
There's a problem with connection to SWR30, e.g.: /t5/SmartBand-Talk/Possible-solution-for-Smartband-talk-bluetooth-disconnections/m-p/1344921#M2412
Sony - Maybe it's time to upgrade to 8.1? (like e.g. Samsung or LG did it!)
Thx.
