- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My phone won't connect to my computer with the USB cable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When you connect your phone, do you see the notification as shown in the picture? If not, I would try restarting the phone, but also using a different cable. You could also try connecting to a different computer. If you are using a Mac computer, you will need either Xperia Companion or Android File Transfer. If a PC, then installing Xperia Companion should also allow you to view files on your phone in Windows Explorer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It needs the driver for USB.
Xperia Companion installs the drivers.
Or find your driver starting here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I don't get the notification. I've tried restarting the phone. I don't have a cable just the one that came with the phone that is about a month old. It will charge the phone so I don't think it is the cable. I've tried a different computer no luck with that either. My computer is running windows 10 and Xperia companion isn't reading the phone either. Thanks for the sugestions though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No luck with the drivers or Xperia companion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem. I plug the phone into the computer and it charges but does not give me the connectivity pop up menu. It used to work fine. Sony, please help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try this.
When it doesn't connect, unplug, turn the plug 180 degrees and plug in again.
