My xperia x performance work great, fast and smooth when battery is full charge or over 70%.
But when battery is 60% or less it's getting laggy . Open apps slow etc
are you referring to this?
/t5/Xperia-X-Performance/Xperia-x-performance-Unjustified-malfunction/m-p/1295565
As you charge and discharge your device, the battery may degrade. Generally the batteries begin to decline after 1 year and a half and seriously declined after 2 and a half years. There either we change the phone because it's already a good 2 and a half years of life for a phone, or buy a battery.
______________________________________________
@worth wrote:As you charge and discharge your device, the battery may degrade. Generally the batteries begin to decline after 1 year and a half and seriously declined after 2 and a half years. There either we change the phone because it's already a good 2 and a half years of life for a phone, or buy a battery.
Thanks for the updates, Appreciated.
