If i charge my lphone it wont charge, then sometimes it charge but just a few minutes then wont charge again
Good chance that the usb connector has given up.
First test.
Your charger plus cable in another phone and another charger plus cable in your phone
Just to be sure if it's the charger or the phone.
Hi @James151, sorry to hear about this.
Where you able to solve this by following the instructions given by @Strampke?
You can always try and charge your device when it's powered off and see if there is any change if it still won't charge with a different cable/charger.
I just want to double check since you mentioned iPhone, was that just a typo? This is the Support forum for Xperia devices!
