Reduced battery life after updating to oreo
Gihanp
My previous screen on time while on Nouget was around 5-6 hours, but after the Oreo update it has redured to about 3-4. I have to turn on the stamina mode to get a decent battery life out of it and I'm not a big fan of the stamina mode.
Hope Sony will fix the battery issue asap, at least by the end of march.
Tags (4)
12 REPLIES 12
Geeronimo
Same here
profile.country.NL.title
Strampke
You're not alone
Look here and here and maybe have some patience.
Maybe the solution lies in here but I think a bit of patience to let battery management settle is worth the try.
Strampke
Patience, patience
Agtpan
Same here dude.
Sakim
I used Xperia x after orio update battery drain quickly
Kindly help
Regards
Sameer Murkute
dstephan
I have the same problem, after Oreo, the battery drains so quick, in only 1 hour I lost 17% from a fully night charge to 83% and the use was only to read 10 minutes my emails.
Please Sony help us ASAP
resa70
severmaya
Same here, lots issues after oreo update.
Most annoying is battery issues, drain very fast.
Please Sony fix this.. Updates ruin everything
Mehrshadkh
Use third-party apps ro manage your applications. I use Greenify usually. I can tell I have twice battery compare to android noughat in normal use.
