- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony xperia x sound is not working and all sound functions has stopped
Hi guys,
All sound functions mic speaker, music, calls are disabled on my xperia x. Camera functions are also not working. It gives error cannot record, recording application is used by another application. Please help. Did factory reset, formatting software repair using Sony companion but nothing helped
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When factory reset and Xperia Companion does not resolve your problem, then options are running out.
What happens in safe mode?
What is the result of tests run in Xperia support app?
Did you restore the full backup after reset or did you start witha clean device (to avoid app related problems)
Tell us about the results please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What happens in safe mode? Same issue in safe mode. No change
What is the result of tests run in Xperia support app? Test gets hung when run for microphone and crashes
Did you restore the full backup after reset or did you start witha clean device (to avoid app related problems) - yes, I tried but no luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I guess that is time to open the support app again and take up contact with Sony support to have your device repaired.
Hope it will bring youa satisfying result.
Tell us the results please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same here. No sound, the mic not working saying being used by another app. Having to send off for repair. Proper pain
