annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
portable charger
RÉSOLU
Vandapcardoso
Visiteur
portable charger
Hi,
Can someone tell me which is the best portable charger for Xperia XA?
Thanks
1 SOLUTION APPROUVÉE
Solutions approuvées
Uliwooly
@Vandapcardoso
portable charger or power bank? if the later then I use a
Sony CP-F10L Portable Power Supply
with multiple Xperias
Voir la solution dans l'envoi d'origine
6 RÉPONSES 6
Uliwooly
@Vandapcardoso
Vandapcardoso
Visiteur
Ok. Thanks for Your answer and advice! 😉
Uliwooly
Vandapcardoso
Visiteur
Just another question:
Portabble supply 8000Mah from Qlive 864715 with this specifications  8000mAh, Entry 5V-1A, out USB1 5V/1A, USB2 5V/2.1A, Acessórios: cabo micro USB/USB 20 cm, dimensões: A150*L77.8*P10 mm, peso: 169 g.
https://www.jumbo.pt/Frontoffice/box_-telecomunicacoes/acessorios_telecom/cabos_carregadores_e_bater...
Do You think this is good for Xperia Xa?
 Here in Portugal I don't find the other from sony.
Uliwooly
@Vandapcardoso
That seems fine
Vandapcardoso
Visiteur
Ok. Thanks again Slightly_smiling_Face
