Mr_North
hdmi link problem
Good evening everyone, I'm having my first issue with my Z3. Every time I connect my micro USB to hdmi lead it drops the wifi connection and the screen connection will drop about every ten seconds. I'm at a complete loss for answers I've try'd different leads and trawled Google for hours for a fix. This set up worked perfectly on all my other Zs.
8 REPLIES 8
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Do you experience the same behaviour if you turn off mobile data > Turn off Wi-Fi and then turn the WI-Fi on again?
Mr_North
Yes still nothing, the phone is only a few days old and the cable set up worked fine on my old z1. Might be worth adding that my wifi completely disappears from my list when scanning for something to connect to.
Hampus
Champion
I can't say for sure, but Xperia Z3 uses a newer version for MHL (MHL 3.0) which Xperia Z1 does not use. Is it possible for you to try another cable?
Mr_North
I'll pop to maplin on the way home and purchase a new cable.
Mr_North
Right new hdmi cable, adapter and USB power cable bought, still the same.
Hampus
Champion
I suggest that you visit nearest service center to have your phone examined by a technician. You can contact your local support team for further information about nearest service center and/or how to proceed with this in the best possible way:
http://support.sonymobile.com/global-en/contactUs/
Mr_North
Cheers I'll look into it.
WilliWacker
Hello,
I have the same problem.
Has anyone found a solution in the meanwhile?
