hello everyone.i have a problem with my xperia tx.i had arbitrarily activated the screen mode for the low vision and blind persons,but unfortunately i dont know how i can deactivate it.i have purchased the device less than 24 hours before!!! and also i have upgraded it to jealy bean. please help me to solve this problem because i cant access the menu.i would appreciate your help
What do you mean can't access the menu?
Settings >> Display >> Brightness
Untick - Adapt To Light Conditions.
Set slide to about 40%.
It sounds like you are referring to the Talkback mode where it speaks everything to you. If so you need to double tap items to access them so this should allow you to access the menu. Once you have done this navigate to Settings > Accessibility > Talkback - Disable.
What are your thoughts about this forum? Let us know by doing this short survey.
Hope you have got your problem solved untill now, I just did the same , now unable to deactivate the talk back mode, I can access the settings but can scroll down to reach the accessibility option for disabling talk back mode .
Kindly help
You need to use two fingers.
Thanks for the support, the issue was resolved.
