No auto rotate.
dave3883
No auto rotate.
I've searched and tried about everything. The screen will not rotate. I attempted safe mode and got an error that xperia home has stopped. Any suggestions?
2 REPLIES 2
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Phy
Legend
Legend
Does it work while on safe mode?
How to boot on safe mode.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
