No wifi, blutooth, signal
noor7abeeb
My experia z1 was working fine
Suddenly wifi , blutooth and signal stopped and dont let me turn them on
Also no emei no baseband
Please help me
4 REPLIES 4
Thommo
Have you modified your device? as the IMEI number going missing is normally a result of doing this
noor7abeeb
No i nevr done that
I was using the phone and suddenly it stopped
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Thommo
If that fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
