Just reinstall the latest update.
What seems to be your battery issue?
The link its broken
That seems to be an app acting up, it could be that you are auto uploading pictures or its just a third party app, repair your phone with PCC and then don't install any app, and check again, you can also turn off WiFi and see if you experience the same behavior
That's the best thing to try at this point.
