iv root my phone with locked boot loader & install timwin recovery for locked boot loader , its very good working then i decide try this CARBON-KK-UNOFFICIAL-20150221-2137-tianchi , copy 2 sd card & flash it whit tim win recovery all down but when i reboot it no responds
try to unlock bootloader with last version flash tools Version 0.9.18.5 but not entering flash mode by hold down vol botton just blink one time red & imiditly green light & agine red then turn led off
warning flash tool : Device connected with USB debugging off
04/037/2015 18:37:43 - INFO - For 2011 devices line, be sure you are not in MTP mode
fastboot mode is work when hold down vol up & plug usb cable solid blue led turn on . device attached & respons when unlock bootloader with given number
FAILED (remote: Command did not succeed)
finished. total time: 0.093s
second time try
FAILED (remote: Device is already rooted)
finished. total time: 0.004s
try s1 tool with testpoint
resul:
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
will use Sahara protocol ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
PROCESSING ...
SERIAL NUMBER : D7E50A04
HARDWARE ID 04000100E1509100 NOT SUPPORTED
HARDWARE ID : 04000100E1509100
NOT SUPPORTED HASH :B77943D5B24F7012CB12EB2FF857C69EAA6518C0E58957AA7 0C0B0590E1F3BCA
Elapsed:21 secs.
pleas help un bricked my d5322
tanx
If you bootloader is still locked then have you tried to manually flash your device using Flashtool and a .ftf firmware file
tanx 4 attention
but sony pc companion or flashtool cant detect phone
when conect phine to the pc detected as somc flash device in divce manager list
if u have s1tool with option s1 MSM8928 emergency or s1 MSM8226 emergency suport d5322 plz refer
d5322 cant go to flash mode
when plug wall charger red led blinking for long time leave it 10 hour on charg but still blink red led slowly
Looks like because you hadn't unlocked your bootloader then that part of the devices software couldn't be written to so leaving your devices Flash partition damaged - you would need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
tanx a lot
you mean that is can be fix by flash with setool2 box ?
I don't use that software but if your device won't enter Flashmode then no, I doubt you can fix it so you will need to speak to Xperia care
tanx boss
sorry 4 intruption
& bad english
:smileysmileythumbsup::smileygood_luck:
