Problems with x10 mini relating to charging form the USB.
Not applicable
When plugging the phone into a USB socket to charge it, the orange light comes on to tell you that it is being charged. It seems to charge for about 5 seconds before it stops and is discharging, even though the orange light is on. Sometimes it charges for longer before it stops. If I use the phone while it is charging it stops and does not restart charging without unpluging the cable and putting it back in.
Last night I plugged the phone into a usb left it there, in the morning the battery was 20%, I re plugged it and now its 50% in 1 hour.
I have tried 2 other cables, all with the same results.
I am going abroad today and it looks like I wont be taking this phone because it is so unreliable when charging on usb, it is bad enough when having to charge everyday with the rubbish battery life but I cant even charge it, without having to constantly monitor that it is being charged? what a joke. My e63 lasted around 10 days on one charge and charged in 2-3hours.
1 REPLY 1
Not applicable
my only guess is it may have someting to do with the power settings on your computer, is it a laptop? i would check your power settings in control panel on your pc, if not then you might need to send your phone to be fixed, i take it that charging through the actual charger works ok?
