- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
top contacts widget is not found after reset of my SL
Since my mobile was filled with unnecessary data and was slow, I restored to factory setting after a backup. After reset I tried to use 'top-contact' widget, I found that it was missing. Also twitter account in settings is also missing and I'm unable to sync my twitter account.
Anybody please help me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's odd, try this
settings > apps > all > scroll to the bottom > perhaps you disable the apps/widgets
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I did. But couldn't solve my problem. Please tell me another solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I'm having the exact same issue. All I could find now is the 'recent calls' widget wich isn't as good as 'Top Contacts" was.Top Conacts didn't update the list so often : most used contact stayed on top even when they weren't the last ones dialed up.
Please tell us there's a way to get that widget back.
Edit : http://exjar.com/file_539651-Top_Contacts.apk-Sony%20Ericsson%20Xperia%20X8.html# found it there as it is no longer in the Google Play library.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I got the Top Contacts widget .apk file from my another Sony mobile and transfered to my mobile. its now working as before. If you need, let me know. I send you.
thanks.
