How to use volume keys for shortcut?
You cannot:
1. Press both volume up and down key -> one key only
2. Long-press the power button -> opens a menu
This is from info in settings.
So how does one do it?
Does anyone know how to make use of volume keys for a shortcut to e.g. TalkBack?
The problem being you cannot press both volumes up and down keys as it is a toggle key.
This is suggested in the setting ( Pie 9.0)
