XZ2 & Android 10 - 52.1.A.0.532
omoeller
Visitante
Just received Andoid upgrade to 10 52.1.A.0.532 - most of the functions seems to work without any hassel. What I recognized is, that the fingerprint reader is responding with a much bigger delay than before - seems to be a high lag time. Anybodey else with same xperience or any other issues?
299 RESPOSTAS 299
DiDaDo1
Visitante
XZ2 here.. turn off "hardware accelerated tethering" in developer mode options and check if all problems still exists..
mnlskies
Visitante
Read on another thread that Software Repair works... and it does! No lags, fingerprint scan is responsive again, no crashes. My only issue is that some words are replaced by chinese characters on the Telephone app_20200118_153006.JPG
Helmser
Visitante
I tried IT 3 Times and it didnt work.
Can you usw voice messages now? Or are they still very quiet?
Manar1261
Visitante
This is exactly what happens for my XZ3
I also noticed the bugs so high.
Manar1261
Visitante
I do. I had the same problem, I just had to restart my XZ3.
But the other bugs are still there.
omoeller
Visitante
"XZ2 here.. turn off "hardware accelerated tethering" in developer mode options and check if all problems still exists.. "
Not enabled - no change to anything and did not resolve a single problem - why should it ...
omoeller
Visitante
Software Repair is not going to resolve any of the problems - you can do rain dances in your garden with the same effect. These problems - as confirmed by Sony Support - have to resolved ASAP with an SW fiy and the Android 10.1 update ...
Ollimax
Visitante
I also have the fingerprint problem with Xperia xz2 compact. Hope Sony fix the bug
LightningStrike
Visitante
Is this a beta software?
Fingerprint, battery, alarm, slow performance.... everything is way off from a stabil release.
DO NOT UPDATE IF YOU NOT ALREADY DONE IT!!!!
Twizztin
Visitante
Same issues here, fingerprint sensor, voice messages. All broken. Useless phone...
