A6700 update.
Dr1deck
A6700 update.
A6700
Just updating to latest firmware. 03.
process has been running an hour getting 5 flashes followed by 9 short flashes.
any advice?
3 REPLIES 3
danardeng
Contributor
Take a look to the guide: https://www.sony.co.uk/electronics/support/e-mount-body-ilce-6000-series/ilce-6700/software/00298439
  • If the access lamp repeats 5 long blinks (0.5s cycle) and 6 short blinks (0.25s cycle), the system software may not have been copied correctly to the memory card. In this case, remove the battery and memory card from the camera, and start over from Saving system software data to a memory card.
you have 9flashes instead of 6, but try
I asked Google's AI, its answer concerns a Shutter problem in the presence of 9 long and 5 short flashes... 🤔😱🤗
Dr1deck
The camera has been returned to Sony for repairs
