Best wat to connect a Nintendo Wii on a Sony Bravia KD55A1 OLED TV.
AMT888
Can anyone tell me the best way to connect a  Nintendo Wii to a Sony Bravia KD55A1 OLED TV?
My new TV does not appear to have the same inputs as previous Sony Led TV.
Thanks in anticipation.
5 REPLIES 5
Deanscooterboye
I think you are going to have to get a phono to HDMI convertor
IamNic
Hi @AMT888,
according to the spec sheet, it has a composite Video input.
Look for the round input, which is yellow around the edge or yellow and green combined.
If you are uncertain if you found the correct input, please upload an image of it to your reply.
- Nic
AMT888
Thanks for the help.  I will try this input
AMT888
Thanks for the advice
IamNic
Hi @AMT888,
so it worked?
- Nic
