i can't access screen settings in system settings.it is greyed out . help me what should i do
It may depend on what input you have at the time. Can you try a factory reset so we can rule out any issues with that.
Let me know how you get on.
Thanks,
Drew
Hi,
Can you please let me know what input you're using and what device is connected to the TV.
Thanks,
Drew
it says "feature not available with current input mode" and it(screen size options) is greyed out in system settings
