i can't access screen settings in system settings.
henryjohnson528
i can't access screen settings in system settings.it is greyed out . help me what should i do
1 ACCEPTED SOLUTION
Drewde
Administrator
It may depend on what input you have at the time. Can you try a factory reset so we can rule out any issues with that.
Let me know how you get on.
Thanks,
Drew
4 REPLIES 4
Drewde
Administrator
Hi,
Can you please let me know what input you're using and what device is connected to the TV.
Thanks,
Drew
henryjohnson528
Sony bravia W67 E ...
Drewde
Administrator
Thanks,
Drew
henryjohnson528
it says "feature not available with current input mode" and it(screen size options) is greyed out in system settings
