Will Sony be producing a pdf for the Help Guide for the XG81 series, the web version is a pain?
@TheLastSnowman wrote:Will Sony be producing a pdf for the Help Guide for the XG81 series, the web version is a pain?
If you look at the first page of the Help Guide Web Version you should see If you want to print the complete Help Guide, see “Help Guide (Print Version)
You can print it or print to pdf. Note you will lose the links.
Yes thanks, printed/downloaded as a pdf 😀
