Sony Bravia 43x8305C --- wont turn off and reset......
The Tv comes on with  "SONY" then the 4 circles, then the TV seems to go off for a second or 2 then does the same thing over and over again.
I have tried to reset it , with the remote and without it, the only way to turn off is by the plug. The TV has always been really slow to turn off and goes blank every now again for a second or 2. I put this down to the sky signal, but now I am thinking it was most likely the TV. It is just over 2 years old, thought it would last longer than this!
Any suggestions would be greatly appreciated.
1 REPLY 1
EdwinaU
Moderator
Hi there,
Welcome to the community.
You could try the troubleshooting tips here. Let us know if this helps.
Best wishes,
Ed
