CMT-G2BNIP - WLAN lost
profile.country.fr_CH.title
luc_tourn
Hello everyone,
I have a problem with my CMT-G2BNIP and the WLAN connection.
The WLAN works well, but the connection is never restored after a power cycle. I need to use the setup function again, confirm all settings, and it works like a charm until I turn it off again.
AP: Apple extreme, wpa2/aes. I don't think it's the problem: I have several samsung phones, tv, players etc which work well. The network level is good (2 bars on the sony display).
Sony firmware: last available.
I also noticed that if I let it in stand by for a few minutes, the connection is restored. Only a long stand by period causes this problem.
Anyone having the same issue ? And found a solution ?
Thanks !
Luc
Tags (2)
1 ACCEPTED SOLUTION
luc_tourn
Solved... sort of. I now use a LAN cable and it works. Wow, fantastic, it's a sony.
1 REPLY 1
luc_tourn
