BDV-N7100 vs BDV-N7200
Argonaut0
What is the difference - what does the new model have the older model does not!?
The older model I see going for £200 less - can anyone let me know what the benefits of 7200 are?
Thanks
1 ACCEPTED SOLUTION
Anonymous
Not applicable
Hi there
I guess what you need to do, is go through the specifications of both to determine which one suits your requirements best in regards to your budget.
For BDV-N7100W see HERE
For BDV-N7200W see HERE
1 REPLY 1
Anonymous
Not applicable
Hi there
