how do you turn off audio description
Hi. I have a 46hx823 tv with a bdp-s480 blu ray. I have a hard drive connected to the blu ray via usb. When i play back a movie i get this annoying audio description of the programme i am watching. Can someone tell me how to disable this please ?
3 REPLIES 3
Anonymous
Not applicable
Hi there
On the TV's remote control, Press the blue HOME button and goto:   Settings > Digital Setup > Audio Setup
Then there is an option for Audio Description.  Set it to OFF.
As per pic below:
miroperdl
HI,
  I have the same problem with a BDP-S790 Blu Ray player.
I can cycle between the various soundtracks but can't find any option to turn off the audio description. It's driving me nuts!
Thanks !
Anonymous
Not applicable
Hi there
Are you sure your not meaning audio commentary?
Anyhow - I thought audio description is on the disc itself - so it may be on the disc's audio menu settings itself.
Try turning off BD Audio Mix in the Audio settings and see what happens.
