No sound/Audio on Netflix 5.1
ronenza
Hi.
I have the Denon DRA-800H STEREO Receiver.
Connected to a New Sony Flat TV Model KD-49XG7096BAEP .
These two connected via New high end HDMI ARC Cable.
When using Netflix on the Sony with 5.1 Audio , NO Denon sound heard. to fix it I need to change Netflix Audio to Original (Not 5.1) then its ok. other Audio is fine , Is there an option to Automatically use Netflix with Audio Stereo mode ( not 5.1 ) ?
Thanks
1 ACCEPTED SOLUTION
rooobb
If you have an VA receiver that does not support multichannel you may want the TV to send digital audio out in PCM
https://helpguide.sony.net/tv/gaepl3/v1/en/060nhm-06-01-06.html#cr-Brv-sync-set
2 REPLIES 2
rooobb
ronenza
Thanks very much indeed for your reply
