Webb
jonnyo1
Webb
Can i surf the webb with SMP-N100?If so-how?
regards from sweden
4 REPLIES 4
Anonymous
Not applicable
Hi there
No you cannot - The N100 does not have an inbuilt browser.  The SMP-N200 does though.
jonnyo1
Ok thanks.Is it possible to stream a movie from a computer on the same network?
Anonymous
Not applicable
Hi there
Yes it is, just set up a DLNA server such as Homestream : HERE and you should then see it on the N100.  See page 15 of the manual : HERE
jonnyo1
Thank you very much,i`ll try if i can get it to work.
regards jonny
