how much battery life can you expect for the sony s series 15 inch laptop with core i7 3612 quad core processor?
profile.country.en_GB.title
Whizperz
hello everyone
can anyone tell me whats the standard  battery life one can one expect on the latest sony s series 15 inch laptop with core i7 -3612 qm processor? also how much can you get with the extended battery sheet as well ?
Message was edited by: Whizperz
2 REPLIES 2
rich912
Contributor
Hi Wizperz,
From the specifications for the SVS13A1S9E:
Standard battery:  Battery Life time (hours)    8 (Stamina Mode) / 7 (Graphics Mode)
Sheet battery: 16 (Stamina Mode) / 14 (Graphics Mode)
Battery Life Disclaimer: Actual battery life will vary depending on your specific hardware and software configurations. Benchmark: MobileMark 2007
http://www.sony.co.uk/product/vaio-s-series/svs13a1s9e
Rich
Go n-éirí an bóthar leat
Whizperz
Thanks rich, i am getting around 3 hrs 45 mins to 4 hrs battery squeese on a single charge for the s series 15 inch  on stamina mode and on power saver option. was wondering why? as sony says around 6 hours. model no-svs151A12m.
usage is normal, nothing graphic intensive yet. normal work , browsing and video.. its a quad core i7 processor spec. its only my 3 rd charge.  i hope its going to get better on battery time as you keep charging or is it a false thought ?
was a bit concerned ,hope the battery time increases. im still to test on with the battery sheet. sony says up to 13 hours with the battery sheet.
is there anything i should look in to ? or does it take 7 to 8 charges before the laptop actually gives proper battery life?
thanks
whiz
