VGN-NR10E OVERHEATING?
profile.country.en_GB.title
cwathen
My Sony Vaio VGN-NR10E seems to be heating up more than usually.  Is there anyway I can check if there is a problem with this.   Thanks
1 REPLY 1
Blencogo
Hi cwathen,
It probably needs a Spring Clean as the air vents collect dust over time and need cleaning out.
Just to be sure of the cause, I would download a utility program like 'PC Wizard' which will show you the actual temperature of your processor when idle and under load. If you post the temperatures here, someone will be able to help further.
