Hello,
I have a Sony VAIO VPCEB1SOE/WI. Does it have bluetooth?
I have been looking for a long time and i cant see it in the specifications. I'm still in denial as i want to connect it to my PS3...please tell me it has got bluetooth...
Thanks for any reply.
Rhys
Hi Rhys,
There is no mention of Bluetooth in the specifications here: -
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VPCEB1S0E_WI&l=en_GB
To be sure: -
1. Turn on the WIRELESS switch.
2. Click the VAIO Smart Network icon on the taskbar.
3. Is there a Bluetooth icon with a switch to toggle it to On? Does the Wireless Indicator light turn on?
If you don't have it, there are very cheap mini-dongles available. Make sure you get one compatible with Windows 7.
Hi Rhys,
To be sure: -
