Recovery dvd's for VGN-SR59VG
profile.country.en_GB.title
mahussa35
I was looking for some recovery disks for  a sony vaio  vgn-sr59vg. when i try to make the recovery dvd's it gets  half way  through he first dvd and then crashes. this has happened a few  times  and i'm unsure as to why. Any help would be appreciated
1 ACCEPTED SOLUTION
Thalamus.
Champion
Hi mahussa35,
you can, if you wish, purchase a set of recovery discs from Vaio support to find the contact details for vaio support either click Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
1 REPLY 1
Thalamus.
Champion
Hi mahussa35,
Then click Log-In
