vgn-nr32s/s graphic card problems
profile.country.ro_RO.title
W4n73d
i have many horizontal lines on my display ..
i suppose its a problem from my graphic card.
i reinsaled my windows but its the same and now when i instal the nvidia drivers windows wont start anymore with drivers only without
anything i could do?
my graphic card nvidia geforce 8400m gt
thx
2 REPLIES 2
Blencogo
Are you using Vista?  Which version of the nVidia driver are you trying to install?
It sounds like you may need to have an engineer look at it.  There are fixes for some nVidia problems.  Are you in the UK?
:thinking:
W4n73d
yes im using vista and i got the right drivers ...
im pretty sure its a defect from the graphic card
im not from uk
