My Sony Walkman NW-WS413 left ear piece does not work correctly (only a very small volume is emitted). I have only used this device for activities such as during running and commuting. What is the solution?
Hi Stheeda,
Welcome to the community.
You could try the troubleshooting steps here and see if they help.
Let us know how you get on.
Best wishes,
Ed
Hi Ed,
I tried above steps, but problem still persists.
Please advise.
Thanks,
Sasank
Hi Stheeda,
Have you made sure that the software of the Walkman is up to date. I found a software update link under the downloads section on the product support page: https://www.sony.co.uk/electronics/support/digital-music-players-nw-nwz-ws-series/nw-ws413. I'd recommend giving this a go.
Cheers,
The_Black_Rose
Hi The_Black_Rose,
The firmware is up-to-date.
Hi Stheeda,
Have you tried resetting the Walkman as explained in the Help Guide: https://helpguide.sony.net/dmp/nwws410/v1/en/contents/TP0000877550.html ?
Cheers,
The_Black_Rose
Hi Stheeda,
That's very strange. Have you made sure that the playback is paused before performing the reset operation?
Cheers,
The_Black_Rose
Yes, I have as I could not hear any music playing when I was performing the reset operation.
Hi Stheeda,
There's not much you can do when it comes to this Walkman than what you've already tried. I suggest you try restarting it and if that fails, take it back to your dealer.
All the best,
Tenneen9000
