Sony nwz-a15
hippysteve
Sony nwz-a15
Is there a docking station for this or at least someway to connect to portable speakers...?
     Not a fan of the loss of sound quality using bluetooth so needs to be using hard connection...
    Would the same docking station for iPods be alright for the Sony nwz-a15...?
1 ACCEPTED SOLUTION
Joe_Dohn
Specialist
iPods and Walkmans use different connectors, so I doubt those will work.
If you don't want Bluetooth, why not just use the 3.5mm jack with a cable directly into your speaker?
J.D.
3 REPLIES 3
Anonymous
Not applicable
Hi there,
Hopefully a community member can help.
Best wishes,
M
Joe_Dohn
Specialist
J.D.
hippysteve
Have managed to plug it into an old 'ghetto' box I have using 3.5 to those red and blue plugs...
   I think my original problem was trying to link it to a digital stereo radio... it linked up via bluetooth but would not link through the 3.5 plug hence looking for a stand alone cradle.
   No matter, happy with the 'ghetto' box...😜
