This is the second pair of these head phones I've had and it's now having the same problem as the last pair which I returned.
The right side cup has a crackling sound or a sometimes a very low level rumbling sound. It used to be infrquent but seems permanent now.
I disable ambient sound in the android app the crackling and rumble disappears.
Seems to be a common problem with these headphones.
Is there any hope fo a fix? Or time to return them??
Hi jljunk1,
Welcome to the community.
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Hi jljunk1
I read somewhere that this is related to air pressure and noise cancelling. Have you tried re-calibrating NC using the Sony Headphones Connect?
Perhaps an update: https://www.sony.co.uk/electronics/support/wireless-headphones-bluetooth-headphones/wh-1000xm3/downl...
or a factory reset: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703081.html
Win_88
