Hi @XA10,
Welcome to the community.
Some operator firmware versions disable the "Internet settings" option for some reason. You will have to manually add the APNs for your network for data to work.
You can add them under Settings > More > Mobile data > Access point names.
Contact your network provider or look at their website to get the correct settings.
It should be under
VPN
Mobile Networks
Internet Settings
Hi @XA10,
