Please help Mobile Charge is not fast ( Xperia™ XA Ultra )
ay_abowarda
Please help Mobile Charge is not fast ( Xperia™ XA Ultra ) Slightly_frowning_Face
I use the original charger and everything is ok .
I do not know why not Charge quickly at 3am until the morning of 11am were Charge only 65% Slightly_frowning_Face
13 REPLIES 13
ay_abowarda
thx poss put 2 hours more Chinese cheap phones with efficiency of few ships in much faster than him Flushed_Face
Fran751
Hi,
Do you have a lot of notification popping up or background apps running? That will cause the charging to be slower. All the lighting up the screen and vibration  from the notification do consume your battery.
1adrian1
Contributor
On the uch20 charger my normal xa will charge from almost empty to full in about a hour. So I'm guessing the xa ultra would take a hour and half tops.
raika072605
Hello im new here im using a tronsmart charger quick charge 3.0 and my device charges only 30 minutes faster than uch20. It seems as if sony xperia xa ultra either doesnt support quick charge or my charger isn't supported. Is there a way to test if which of them is the case? I spent a lot of money on this charger so i would like to find the answer at least. Thank you!
