- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
probleme xperia z2 whit magnetic charging dock
helllo
I have a problem on my xperia z2 when I put on the magnetic charging dock DK36,the mobile is loaded with the dk36 then quickly discharged and it repeats the same thing
please can you help me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you saying that the phone does charge when its connected to the dock but when you use your phone it discharge fast? if so, that's not the Dock, its all about the apps you have running in the background, how much time you have the screen on, how many apps/services are you syncing, how many games are you playing, how good/bad is your network coverage, etc.
charge your phone 100% > restart your phone > make sure that its still at 100% > if not let it charge a little longer > once it reaches 100% > use your phone as you normally would, once it reach 50% go to
settings > power management > battery > check the graph, also check the top 4 items on the list, check the percentage and the amount of hours and minutes and post all that info here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello,
i'm sorry i didn't explain well,so when i put my phone in the dock it will connect then it disconnects quickly and it repeats several times
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is it connected to mains socket or USB port on a Pc for example?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yes ,Is it connected to mains socket
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is it one with a removeable USB cable or fixed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'd suggest a system repair to rule out software issues then if that fails it's either the dock or an internal hardware fault
Performing a system repair using PC Companion will factory reset your phone and erase all data so best to backup before you begin
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
and as said if that fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
