Xperia SP(C5302) touch not responding while USB charging especially with Vaio systems(when the system is also on charging mode) and occasionally touch lags when charging normally.Any suggestions..please help??its getting quite cumbersome..
tried enabling and disabling the glove mode and everything..but the Vaio system problem is persistent and the normal wall charging touch problem creeps in occasionally...
using the firmware 12.0.A.1.211.
please help..
Do you have a screen guard on?
Try using without a screen guard. I had the problem when I was using a screen guard. Got frustrated and removed it. Now the touch is silky smooth again!
better i would suggest u to replac your phone with a new phone,and on the new phone better do not connect it to pc and charger other than the original provided and also be cautious while connecting it to pc.
i also faced the problem and got my phone replaced.
I hope Sony will fix this. When you unlock the phone and it not start, is annoying. WiFi range have to be fixed to.
Guys problem might be rrm the screen protector. I just removed to make sure of that and it worked. .screen is scratch resistant so dont have to bother about geting scratches.
Try lower powerded output voltage charger.
I was having same problem.
The original sony charger is giving 850mA output power.
But when i have tried samsung charger with output power 700mA, touch is working fine.
On the other hand some PCs may give higher output power than the mobile needed.
So touch will not work.
Some smart phone having this charging problem.
I have seen the problem in some of the htc, micromax, and my phone Xperia SP.
Same touch unresponsive problem here. It doesn't matter if I'm using the charger that came with the phone or a different one. Updated the phone and it makes no difference.
I am also facing similar issue. when i keep my handset for charging, screen stop responsing.
i use charger provided along with headset.
i have done factory reset and its updated with latest firmware. but still its issue.
please help.
@cosmicrajeev wrote:hii tunir..
u're right..the problem doesn't persist when the charger is removed..and i did get my phone replaced once cuz of the same problem..but the main problem is that the replaced one also suffers from the same problem..that's my main concern as to why is this happening??is there some problem in the SP range itself??cuz the other sets don't have this problem..i tried this on Xperia Z,Xperia U,Sola and Live with walkman(of friends ofcourse)..
Just and hour before I bought this mobile and have same problem of hanging while connected to PC. Have any one solved this without going to customercare ?
Help please....
Help please....
Help please....
