Z1 Compact Battery Life
Lee17
So after my phone went for a swim, and took about 3 weeks to switch back on.....the battery life is terrible. My phone used to last for two days and now lasts for just under 24 hours with normal usuage. Is this Expected or could it be a serious problem?
6 REPLIES 6
Thommo
Sounds like you had water ingress so this could be a factor to consider that your battery was diminished
Lee17
Is it possible to change the battery?
Uliwooly
It is possible, but if you DIY you will void your warranty
Uliwooly
Lee17
my warranty is already void, the water indicator is yellow....and apparently its all because of my "negligence".... But thanks! I will see what I can do!
Uliwooly
Did you requested a vacuum test?
