Hi,
Anyone else having this problem with the USB connection. Charging works fine att all times.
Problem seems to be with the data connection, where sligtest movement near the phones usb port causes disconnection-reconnection cycle. It happens with different cables (some worse, some less but happens), and with different devices. I use it with PC and with drone controller. I could live with this if I was just using it with PC, but in drone usage its almost impossible be totally not moving while being outside flying. This is a bit frustrating and can also cause some harm with the drone if disconnecting videofeed in mid flight. Anyone else living with this?
