Front light
Cmichaelam
Front light
Hello
KD-43XE8077
Does anyone know how I activate the cyan blue front light on this TV? It's not available in the LED illuminations button oddly- and annoyingly. I'm thinking of sending TV back, ITV player intermittent + other apps!
2 ACCEPTED SOLUTIONS
profile.country.HR.title
kinggo01
Contributor
AFAIK, you can't change the colour. Colours are predefined by different system functions or status.
Cyanblue was default "power on" on B sereis from 2014 but from C onwards default is white.
Jecht_Sin
Enthusiast
@Cmichaelam You can change its behaviour, though. Just go in Options and then into the LED settings menu. You can dim it or have it enabled only when you use the remote control. Even disable it completely if you like.
6 REPLIES 6
kinggo01
Contributor
Jecht_Sin
Enthusiast
Cmichaelam
Hi
the Illumination LED setting button provides 5 options:
1) Demo
2) Auto-brightness
3) Dark
4) Simple response
5) off
None of the above options turn the light at the front of the TV to cyan blue, like the shop display model, am I in the wrong section?
Cmichaelam
Hi
The Illumination LED setting button provides 5 options:
1) Demo
2) Auto-brightness
3) Dark
4) Simple response
5) off
Cmichaelam
Oh I see, perhaps the one in the shop store isn’t displaying this then, it could be a different model. My mum was sure the one she seen had this feature, my previous TV had it too. The LED is very subtle, hardly even a feature.
sameeroza8196
nice
