kd49xf8505bu sound issue after update
johhnyhotrocks
Hi, after updating my TV when I power down the soundbar mutes itself and I can only get sound back by unplugging the hdmi and reconnecting it. The sound bar is Panasonic and when I purchased it and connected by arc hdmi everything worked perfectly. This issue has only started after the TV updated.
Thanks
11 REPLIES 11
profile.country.GR.title
panlask
I put the update and things are like that:
  • Most MKVs play with 5.1 sound properly with the built in player
  • Some still have issues loading (probably a sound or other format issue)
  • Those that do not load, play very well in Kodi
  • But Kodi plays only 2 channels no matter what (even with pass through on)!!
  • Youtube doesn't play 5.1 but I believe it wouldn't suport anyway
  • Netflix etc. I don't have so far
So, this is a partial solution to the previous update issues.
johhnyhotrocks
OK, I need to correct my post. After switching on and off a few times it seems to be working fine now. I'm just glad I had left the arc lead plugged in.
