Hi there
Have you looked or experimented with the A/V Sync settings (page 38 of the manual : HERE)
Hi there
Glad it works
So close on that page number !
Unfortunately I cannot see a way to adjust background music to speach etc. Its probably the way its encoded. You can only change the individual speaker distance and level.
